XR250L rear brake expectations?
I have a 94 XR250L which while hopped up has been poorly maintained.
As an aside it has a 284 BB kit, Keihin pumper carb, xrs only exhaust, and an
Acerbis 5 gallon tank. Not bad for $500.
But... Both brakes were shot. I replaced the rear MC and bled the system
pretty well, and am still getting what I think is a soft brake. I am comparing this
to my street bike experience, especially my current ST1100 which has good,
strong brakes. On the XR I can currently push the brake to the stop and still
roll the rear wheel (with heavy resistance) in neutral. Is this normal? Am I
asking too much of these small brakes or should the rear caliper be able to lock
the rear tire up with a good hard press?
Thanks!
Edited by firtree
ah, grammar...
just picked up my '99 xr 250 and i can lock both tires and impossible to push..
i replaced both rotors and sets of pads with some ebay specials (both were well over 1 mm under the spec limit!). they work pretty well. bled the system as well. your pedal/lever may need to be adjusted as well. i had to take the locknut off of the front lever and put it on the inside so i could get more travel
i have a 92 XR280L, my brake pads are fine, but I'm sure the rotors are either past the limit or right at the limit and i can lock up my brakes and slide all day long. so either keep bleeding the brakes and if that doesn't help then it must be something like calipers or rotors.
Thanks guys! I ended up bleeding it some more and adjusted the pedal throw to push on the rear MC longer. Now it is stopping well. Now I just need to get the front brake on, fab up a rear light and get her on the road!
