ktm 09 200xc-w fork shim stack
Here are my shim stack numbers (stock). I'm in the process of changing the compression valving a little. I was told to take a few shims out so i'll see how that goes.
Also I'm gonna change the mid-valve a little bit.
After the compression piston-
(5) 24 x 6mm id
(1) 22 x 6
(1) 18 x 6
(1) 16 x 6
(1) 14 x 6
(1) 12 x 6
(1) 8.5 x 6
(1) 16 x 6
Here are therebound and mid-valve numbers-
(1) 14 x 6
(1) 10 x 6
(1) 12 x 6
(1) 14 x 6
(1) 17 x 6
(3) Delta shims
Rebound piston
(2) 18 x 6
(3) 20 x 6
(1) 18 x 6
(1) 16 x 6
I can't really tell the width of each shim because I don't have the best micrometer.
i have not done much on this fork, but you want a float of about 0.35 and i would guess std is about 0.5 to 0.7mm, then you need to tune the base for the correct feel.
  • 4 weeks later...
