DR350 - needle seat??
Hi all.. I finally got my bike to start but cannot get it to idle.. the carb seems to be leaking out the over flow on the bottom.. I found a post that says it is the needle seat, but I do not know what the is.. is it the seat for the float needle?? do I need to adjust my float level first or should I tey to replace that piece in the carb first?? thanks for the help!
cool.. will try that.. what about the idle? it seems that I can turn it way up and it will idle high, but not low..
Probably the same as Rob mentioned.
It doesn't take much "mung" at all to mess up the pilot circuit which controls the idle.
Sounds like a good thorough carb cleaning is in order.
├Ś
├Ś
