Just picked up an 08 today what do you guys think?
the last time i went out for a ride on my 03 i made the decision it was time to get a new bike...
after a few searches on craigslist i came across this
guy "said" has low hours, new piston, while he had it there was no valvetrain rebuilt. got it for $3050 good deal or not? i bring up the valvetrain because it seems that the head casting does not directly line up with the cylinder casting for some reason
also after riding my 03 the power on the 08 seems more spread out any comments on that?
If I were you I'd go all the way down to the piston and check to make sure EVERYTHING is in spec.
Serious!?? Na way! Stuff that! Why would you want to do that to an 2008 model!?
If the bike runs fine, goes hard, just Ride it! Dont fix it if its not broken. If any problems arise, then look into it.๐Ÿ˜
& Pica, WOW..... 476 posts in one month since you joined!!? Wow..... You've nearly caught up to me & Ive been on for 6 years...
Ok I wont say what Im thinking........๐Ÿ˜
i dought the pipe and forks will work. this is what i would do to inspect a bike, pull the clutch cover off cheak the basket for groves. pull the valve cover off cheak valves ,inspect valve buckets and cam for wear. its prety quick and easy.
I would! Like he said, 40 hours could mean nothing if it was lightly trail ridden, but if it was hardcore raced, then 40 hours could mean the end of that piston. It hurts nothing to check and doesn't take that long.
Also, holy crap, I had no clue how many posts I had haha. I'm not even on here that much. Few times a day, and I guess I just post a bunch in those few times haha.
well ill tell you a story about my day...
i decided to go out on the 08 today for the first real ride and i loved it. but i had one issue, the fing mechanic who the old owner paid to put a new piston in it right befor i got it didnt tighten the cam sprocket bolts on it correctly.๐Ÿ˜ so as im riding it i hear a weird noise n i stoped the engine once i found it was hard to start.
went to honda and got 2 new bolts and put them in and wala:ride:
i checked timing and it was still on, luckely the one bolt just fell out of the cam while i took the head cover off and the other was a little less than finger tight. close call! $6 for each bolt! i tightened them to 15 ft lbs and put her back together to find out there was no damage done, of course this is after pulling left crankcase cover off and geting metal shavings out because the cam gear dug into the head cover a little bit. i looked into spark plug hole with a diognotic camera my friend had to find no piston the valve contact THANK GOD!๐Ÿ˜ the bike ran great after i also changed oil 2 times to make sure all alluminum metal shavings were gone
ร—
ร—
