someone please help!!!!!
i got a kx 125 project. its is a 1987 it has new main bearings i took the cases apart cleaned everything. i got it back together and it wont run. i cleaned the carb REALLY good twice. set the floats everything with the fuel system is clean and works. i have a brand new plug and new fuel. i tried ether and it still didnt want to start. i have tried choke and everything. someone please help. btw i do have 3 years experience with bikes of all kinds. so i will know what you are talking about if you use a "big" term.
yes the carb is getting fuel and the spark is very intense. a bright blue. gas mixed 32 to 1 new plug. fuel in bowl everything seems to be working. fuel. air. spark. and compression. as you know the things needed for an engine to run. she just wont fire over.
i decided to drain the bowl then kick it over. it was flooded like crazy. thank you for taknig the time to answer my thread. it did help somewhat. time to go rip (well tomorrow anyway lol
bbbbbbbrrrrrrraaaaaapppppppp brap! :cheers:
