TW 200 Tail Lights... Should they or Shouldn't they?
I just picked up a 89 TW 200 last weekend and while going over it I noticed that the rear turn signal lights don't operate in a running light mode. With the key on the front signals are lit all the time. They flash when you switch on the turn indicator. In the rear the signals only light (flash) when you turn on the turn indiactor switch. I thought maybe the bulbs were bad but when I checked them I saw they were single element bulbs. Which tells me they were never suppose to burn all the time. Is this correct and if so does anyone know why or were my bulbs replaced incorrectly at some time?
Thanks for the insight.
your front turn signals are also running lights, which are always on, the rears ONLY light up when the signal is activated, which is how it should be. your bike is just fine, there isnt anything to be woried about.
