FCR Fuel Screw O-ring and Spring?
Finally got the FCR and am currently installing it. Pulled out the stock fuel screw while I was checking the jets just to make sure they were correct. I noticed a few minutes later that there was a small o-ring and spring on the table. I'm assuming it came from where the fuel screw was. Can anyone confirm this and if so does the o-ring or spring go in first. I doubt it makes a difference but im putting in the extended fuel screw. Thanks guys.
edit: ok just noticed a small washer the same size as the o-ring.
Edited by JAKOVASAURUS
new info
