Anyone running a Dunlop Sportmax Q2 160 rear on the 4.5inch sm rim?
Hello TT community, Im wondering if these tires will fit alright on the stock rim and if there is any clearance issues, im guessing it may rub on the chain but aslong as its not rubbing on the swing arm it will be alright. I did a search and I know most 160 rear tires will fit but didnt find any info on the Q2. I know 150 is the optimum size for the 4.5 inch rim but getting a good 150 rear tyre in australia is next to impossible. I was going to get a 150 pilot power on the rear but these arnt imported into australia apparently. Anyhelp would be great Thanks Jerome
Edited by Romie
Try shinko Podiums 150/60/17 see if you can get one of those over there. Also if you have the stock dunlops on the bike you do not have to get a new tube with a 150/60/17 as the stock tube is also marked for that size. It will save you some money. I found out after I dismounted the tire. I could have reused my stock tube which there was nothing wrong with.
