Rerouting Throttle Cables
I noticed on all of the Factory KTM race bikes, the throttle cables are routed down behind the front number plate. Is it possible to do this on my bike? I don't know if the throttle cables are long enough. It seems like if I rout them that way then it will tug. Are my throttle cables long enough to rout this way?
i use them from a kx250f . it fits for 90 % .the only thing you have to do is make the ferrules at the throttle sleeve smaller or use the compl. throttle assy from a kxf . the kxf cable,s have also the adj. just near the assy. the kx cable is also a lot stronger where it go inside the throttle housing .
