2007 TE250 Valves
Couldn't find the answer although a couple people did ask....are the stock valves in the 07' TE250's titanium or SS? I adjusted mine and one of the intakes was VERY tight so I see new valves in my future. THX!
Thanks George! Yes, I did set up a carb vent/filter system. I do a lot of long, dusty dual sport rides on the poor thing. Would I be able to replace the valves myself or do they need to be grinded etc?
Can't grind TI valves, or even lap them as it will cut thru the hard coating, then into the soft core material.
On the Carb vent filter Mine or other?
Also any dirt on the top of carb, slide area?
Later George
Can't rememeber the brand off the top of my head but the carb kit has one way valves and filters on the ends of the vent hoses. I had trouble with deep creek crossings and researched that the vent hoses suck water so I re-routed them and put this kit on it. Seems to be a swamp monster now. Anyway....I was going to put SS valves in so that's why I asked about grinding (lapping) them. So you can put new SS valves in without cutting/grinding them??
