Cylinder Works Compression
From what I gather, the 94mm kit with the Vertex piston is 11.3:1, correct? I assume that this is with the three layer base gasket. If I run the single layer base gasket, it would be around 12:1, correct?
I currently have the single layer gasket on my DRZ, and I'm concerned with going with a big bore that would lower the CR. If I can achieve the same compression that I have now, I'll go for it. Otherwise I'll keep shopping for another kit.
Thanks...
├Ś
├Ś
