Dell Taco to 01 YZ Forks.
I'm in the process of installing the kit and am having a bit of trouble. The instructions that I have found online seem to be for the newer style forks and a lot is different. All of the shims are of different sizes and my kit did not come with the stiffer springs. I was just wondering if there was a guide for the 01 style forks because I'm completely lost right now and I was just wondering if I complety missed a thread on it or something. Thanks.
Breezy,
See if this helps you out. https://thumpertalk.com/forum/showthread.php?t=313194
https://thumpertalk.com/forum/showthread.php?t=336140&parentpage=5
Do you have the forks apart yet?
You will only have one MV spring, #175 Make sure that the spring is
placed on the stem correctly. The lower rung of the spring must sit
flat on the stem over the shoulder. You may have to pry it over the shoulder.
shoot me a pm or an email if you have anymore questions or you can post on here for others
to chime in.
James
Edited by jwaseman
