05 TRX250EX "Start in gear"
Yes it can be done and you can do it a couple of different ways.
First - unplug the neutral safety switch and put in a jumper wire to bypass, by doing this your green neutral indicator light will be on all the time.
Second - you can wire it so that when your brake light is on the neutral switch is on also. You can do this with a simple relay wired parallel to your neutral safety switch so that it will work both ways. The only downside is your neutral light will come on each time you use the brakes. (This is the method I would use)
Good luck.
