RM 125 front end alignment
2 people needed, 1 holdes the front tire between legs the other is on the bike turning bars. I would only do this in a pinch.
I recomend loosening all the front clamps allowing the fork tubes to straigten by themselves. then tighten everything up.
Good luck
I have always just stood in front of the bike, squeezed the wheel between my knees and pulled on the bars to twist it back straight. It takes 2 seconds and only one person is needed. If you can't get it like that then you can loosen the pinch bolts on the triple clamps and twist it back.
