05 Rebuild
Rod bearing went and frooze up crank...I split the cases today and found this. Since the crank doesn't sit directly on the casing lip, will this be an issue? Thoughts and opinions, please. Has anyone seen this with brass only from the rod bearing? Both main bearings were good...
