Clark Desert tank
omit 3 & 4.reuse 1,2 and 6 using the screws provided with the new clarke tank.
install the seat mount metal spacers into the rubber grommets located at the back of the tank.
slide tank onto the front frame mounts.
bolt tank down in the back using the original bolts.
install the seat,carefully aligning the groove in the seat with the new rear spine mount.i had to trim back the new spine mount a little to get a good fit so the seat wouldn't wrinkle when installed.
install the safety strap provided for additional stability.the open ends of the loop face down.
install the shrouds with the screws provided and attach the fuel and vacuum lines to the petcock.
