Could use a little tranny help
03 CRF450R---Oil changed ever 5hrs
Was out yesterday and was hitting neutral allot (just figured bad day) Then the last time I could not get it to go into any gear. After several attempts it went into 1st, but will not move to any other gear or neutral. Any ideas?
Chances are it's toast and time to split the cases. I had those same symptoms on my '09, false neutrals everywhere, wouldn't shift into 5th.
All gears on main shaft and countershaft are toast, forks toast, shift drum history....Even if your damage isn't that excessive, you'll still have to split the cases to inspect and replace.
Also, pull your drain bolt, chances are the oil will be "shimmery", then take a small magnet and stick it into the drain hole for the trans, I bet it gets shavings all over it.
├Ś
├Ś
