ideling problem
Sounds like it's either idled too low, or it's lean on the idle circuit. If it's too lean on the idle circuit, it may be a very small peice of debris in the idle cicuit, or maybe just a small turn of the fuel mixture adjustment screw. Just about any general moto tech can look at it a figure out which is idle adjustment, and which is fuel mixture adjustment.
Either way, if you get no response here, I would post this in the Kawi forum.
my cousin has a 93 kdx 200 it's turned in all the way on the idle adjust screw and barely idles. the screw on his is the big knob with an external spring under the head of the knob. there is also the air screw. it's the little one to the right (on my cousins). it has an internal spring which can't be seen until it's taken apart.
├Ś
├Ś
