2011 crf450r
FIRST LOOK! 2011 HONDA CRF450 & CRF250
Honda made the same changes that the tytpical CRF450 owner made last year; That's good engineering; The CRF250 gets a new map, muffler and HPSD damper
2011 Honda CRF450.
Honda press release: Motocross is a battle, and you’d better bring your “A” game whenever you show up—either that, or be prepared to eat a bucketful of roost. But when you’re on a 2011 Honda CRF450R it’s everyone behind you who’ll be savoring that dirt-flavored banquet. Why? Because we’ve given the CRF450R some serious upgrades.
First, the 450 gets a new 46mm throttle body, new fuel injector, and new ECU mapping so the engine makes more low end and midrange torque, and also offers even better throttle response. The power is easier to control, but without any loss of top end—better than ever for intermediate and expert riders alike. And our chassis designers were just as busy, updating the CRF450R subframe and taking the opportunity to fine-tune the subframe's stiffness. A new rear shock link and lower shock mount for improved front/rear balance and better suspension action especially over square-edged bumps.
And finally, new 2011 AMA rules state that every MX bike will have to meet the new 94 decibel rule. Both our CRF450R and CRF250R do that easily, thanks to a new exhaust system that works in conjunction with the new FI settings. So while the other guys might just change a muffler, that’s just where we started. And the first time the gate drops, it’s gonna show.
2011 CRF450 SPECIFICATIONS
Engine Type: 449cc liquid-cooled single-cylinder four-stroke
Bore And Stroke:96mm x 62.1mm
Compression Ratio:12.0:1
Valve Train: Unicam, four-valve; 36mm intake, titanium; 30mm exhaust, steel
Induction: Programmed Fuel Injection (PGM-FI), 46mm throttle body
Ignition: Full transistor with electronic advance
Transmission: Close-ratio five-speed
Final Drive: #520 chain; 13T/48T
Front Suspension: 48mm inverted KYB® Air-Oil-Separate (AOS) with rebound and compression-damping adjustability; 12.5 inches travel
Rear Suspension: Pro-Link KYB single shock with spring preload, rebound damping adjustability, and compression damping adjustment separated into low-speed and high-speed; 12.6 inches travel
Front Brake: Single 240mm disc with twin-piston caliper
Rear Brake: Single 240mm disc
Front Tire: 80/100-21
Rear Tire: 120/80-19
Wheelbase: 58.7 inches
Rake: (Caster Angle): 26° 52'
Trail: 114.5mm (4.5 inches)
Seat Height: 37.6 inches
Ground Clearance: 13.1 inches
Fuel Capacity: 1.5 gallons
Curb Weight: 236 lbs
I am kind of ... "WHAT???" ... I don't understand why EVERY YEAR Honda keeps people waiting for the launch of their next model year, while EVERYBODY else has already introduced their bikes.
Sure I can see it if there are a lot of changes, but new mapping, shock link and HPSD ... seriously ??? ... that was the "big wait" 😏 Oh and a longer muffler.
Looks nice overall 😏
The 46 mm TB would be inline with the rubber intake manifold as the 2009-2010 TB tapered from a 50 mm plate to 46 mm @ the rubber manifold . I have modifyed the KX450 f TBs to 45 mm with a speceil TP and was able to get them to flow with in 20 cfm of the hondas .
