93 CR125 problems...rebuilding.
So as I stated in here awhile ago I bought this bike a while ago with a known transmission problem. The bike would start and run, but when shifting from gear to gear sometimes it would not go in gear and shift into neutral, Is this the shifter fork? Thats what I was told but am not sure.. i am in the middle of splitting the cases but am stuck on the flywheel bolt under the clutch plates. I have un bolted everything else and have the cases split, just held on with that one bolt. It seems that all the little gears on the right side of the cases wiggle around and seem loose, is that normal? any help on what could be the problem that I needa look for, and any tips or write ups on how to do a bottom end and put back together would be much appreciated.
