2004 CR 250 swingarm compatibility
I am looking for a swingarm that will fit my 2004 Honda CR 250. I have been to the dealer and the part numbers don't match up and I could not find a definitive answer. I think the 2002-2007 models will work but need a definite answer before I buy. I don't care if it's perfect, it just needs to work. Thanks!
The 05+ has different linkage and shock length, but with these items will fit.
02-04 will fit, as will 04 CRF250R. 04-05 CRF250X should also work, but is a bit different in flex and I believe a bit shorter.
02-04 CR125 will also work with different swingarm spacers.
Thank you for the precise feedback, greatly appreciated! Ended up going with an 03 250 one, had some chain adjuster problems but got that fixed and ready for the bearings.
