Raptor 660 electrical issues
I have an 01 660 that ran fine. I was riding it the other day and the reverse light started coming on. The engine would cut out unless you pulled the clutch lever in just enough to take out the slack in the cable. Eventually it quit. All electrical, starter, lights, ect. don't work. The quad will start and run fine if I pull start it though. Any suggestions would be appreciated.
Ok the reverse light flickering on and off is ground signal is going bad. I removed the wire on mine and went strait to ground to fix the problem. The rest of the issues you have is not good, you may have to replace the whole wiring harness.
