'84 xr250r wiring help??? plz???
I've got an '84 xr250r with a dual sport light kit on it. I'm not sure who made it, the only name on it acerbis on the headlight and tail light plastics. My problem is I was trying to get the turn signal to work and unplugged some of the harness while pulling it out of the overstuffed air box. Now I have no spark and can't figure this wiring mess out. The problem is some where between the factory harness and the aftermarket lighting harness. The regulator/rectifier has 2 yellow wires and a red and a black. One yellow is gronded to the frame the other is unhooked from anything ( my problem???) Where does this go? did I mention I can't get the spark plug out either. Need to get a thin wall socket. I am at my wits end and the factory diagram is useless on this. Please help??? Thanks. I will also post this in the XR forum.
