first oil change on 86 xr600
oh k so i got the bike bot 3 years ago and dont ride much. had new oil in it when i got it and its just now turning brown. gona put amsoil bike 20-50 and a new filter. and ever were i read they say check the screen. and the only screen i see in my book is the one under the clutches. is this the one i need to check? or are the refering to the oil strainer in the frame?
They're referring to the frame strainer. It's a good idea to check it once in a while. It's usually in there very tight though. I lay my bike on its side so I can break the torque; otherwise, the bike would fall off the jack first.
If you don't feel like fighting with it, just change the oil. Unless there is something VERY wrong, it won't be clogged.
