IMS Tank Install
Finally installed my 3.4 Gal IMS tank.
So question to all you tank modded bikes out there. The two anchor nuts at the front of the tank...
Guess the top bolt on the OEM tank is not used and the two anchor nuts integral to the IMS tank do not bolt up to nothing?
Just the rear strap under the seat and the two bolts on each side panel hold the tank in.
