carb maybe???
Stuck float in the float bowl, wack the side of the carb with a wrench. If that doesn't work you will need to remove the carb and check out the float and needle valve.
I kinda figured that was gonna be everyones response... when you say the float is stuck open, does that mean its stuck in the down position or its stuck floating to the top?
okay, another stupid question... the choke on the carb, is it on when it is in the up position or the down.... my carb i way messed up and it doesnt seem to make a difference where i position it. the bike will start and run when the choke lever is up but as soon as i put it down it dies.
