2006 vs. 2008 Clutch
I need a new clutch assembly for my 2008 YZ250F. Would a 2006 assembly (plates/basket/hub/pressure plate) directly bolt-on? I did a search and didn't find much info. It sounds like the 2009+ has a newer basket, but I though I read somewhere that the 2008 plates are different than the earlier models.
TIA!!!!!!!
09+ use rubber cushion on the driver gear on the back of the clutch basket vs the spring on the 01-08 plus i think there are a few other differences.
why do you need a whole new clutch assembly? if the basket is shot upgrade to a new wiesco basket its best money can buy.
Oops.
My bad.
I thought I read WR-250F, and not YZ-250F.
As pointed out, the 2009 YZ has a different clutch basket (AKA primary driven gear).
Go to the Yamaha parts catalogues and compare part numbers to see what is and isn't the same. ­čśĆ
├Ś
├Ś
