brakes
Here's a quick trick to try on the fly. The knee trick. Grab your front wheel with both hands. Put your knee on the caliper & push hard & press the caliper in. Then pump your lever & see if it's better. You can do the same on the back too. If your fluid is black & old you need to bleed everything out good.
