04 yz250f OIL QUESTIONS
i know this has been posted many times but ive seen all posts and stuff and how to but 😏
I drain my oil from my frame at the bottom and then under the shifter? right?
then where do i fill just on the side cover?
and how much oil all together
Also i have seen that people use all kinds of oils
10-40?
15-50?
20-50?
and synthetic or not?
all help is appreciated:)😏
Drain from oil tank on frame then the engine. fill it up on the black filler on the flywheel cover. They hold 1.2 quarts sometimes more or less. I just a motul synthetic 20w 50. I find it makes the bike shift much better. You can run a standard 10.30 or 10 40 with no issues either. I used to run delo 400 15.40 in it for years. There a hundreds of oil threads on here just run what you like. If you do run a synthetic make sure it is wet clutch compatable.
thanks
