Do we have cartridge fork or Twin Chamber?
Rocky has some video's, but need to know which fork we have. The brochure says cartridge, but also has AOS which sounds cardridge to me.
Need to install springs and new seals quickly before the Idaho Spodefest.
Research indicates 5wt oil stock, is that correct? And at 240# should I go w/ 7.5wt?
Edited by mxphlipper
There is step by step instructions in the workshop manual on how to service the forks so just follow that and you should'nt have any problem.The thing you may need is a top plug spanner I think it is 49mm but check that its been a while since I had mine apart.
Edited by SSPI
mistake
