Need direct fit bars no clamps
My stock bars need to go and I am looking for the most rise without adding clamps OR modifying the cables or other parts. Can you steer me in the right direction?Also, When purchasing bars, what diameter am I looking for?
Thank you...
D
I have the S and here is what I did.
Bar risers, converting standard bar to oversized $80
http://www.rockymountainatvmc.com/productDetail.do?navTitle=Handlebars-Control&webCatId=12&navType=type&webTypeId=70&prodFamilyId=27406&listingId=&sizeAttr=6665&colorAttr=
Pro tapers, travis pastrana FMX bend $70
http://www.rockymountainatvmc.com/productDetail.do?navTitle=Handlebars-Control&webCatId=12&navType=type&webTypeId=70&prodFamilyId=8610&listingId=&sizeAttr=2946&colorAttr=
The risers give you a couple inches and the bars have a lot of rise 120MM if I rememeber right.
I'm 6'3" and I can comfortably stand with this setup.
If you have the SM you have a different top clamp and can/need to go another way
Thank you...
D
If an S or E, Pro taper SE 7/8 bars in CR high.
If an SM, then Pro Taper EVO in CR high
