Send entire motor to Thumper Racing for Big Bore install??
I'm really considering the 280 big bore option for my 96' XR250r. It seems that people are generally pleased with the 277 option from Thumper racing. Is it worth me just sending my entire motor (I think it costs an extra $240) to them and having them put the kit together and then just remount the motor and go??? Or is installing the 277 kit simple enough??
hey PlanoXR
i sent my motor down to them. it was like 80 dollars each way. 3 weeks later i bolted the motor into the frame. added oil and gas, she fired right up. just be prepared to spend a little more, if they see something worn out or bad they will replace it. its a little more peace of mind. plus if something fails you can complain like hell and they will fix the repair.
mine pulled the threads from the block after the break in period. so i had them fix that. free of charge.
