a question about handlebars
The wall thickness in the center isn't enough to accommodate the cross bar being removed. It might last you a little while, but eventually the bars would just fold on you, possibly even work harden at the clamp and snap off.
Aftermarket clamp or risers and oversize bar is your only real solution.
yeah no one will answer my other thread about the difference between the solid mounts and rubber mounts
the rubber mounts absorb a lot of vibration and you can generally get more offset options on the rubber mounted top clamps
I go the cheap route, and use ATV bars. It looks hella stupid, but it serves the purpose. I have been running ATV bars for about a year now.
Are ATV bars the same width as bike bars? Does your throttle tube fit on them w/out any modification? Is there a purpose you get from the STV bars other than inexpensive bars?
MAX!!!
