head gasket leaking
Do any of you had head gasket leakage problems. I'm not losing any coolant apparently but it's always wet around the head gasket on the right side. Do you think that only torquing the head nuts has a chance of giving any good results. I removed the valve cover and torked the 3 accessible nuts, unfortunately the other one is under the cam bearing holder. The nut that I can't reach is aligned to the area where it's leaking.
Any ideas
Thanks
dany
