Drz125 conversion to a 125L
My question is is it possible to convert a drz125 to a 125L if so how. i realize the L has larger wheels and a longer swing arm. is it as simple as purchasing a 125L swing arm and replacing the current one with it and then making the minor adjustments like a new chain and new wheels or is there a whole lot more to it than that?
For the work involved, you should look into the KX100/RM100 swap. The total cost for us worked out to about $450.
Parts Bike 200
Gas 50 (two hours one way)
Chain/Sprockets 123 (note: you can do this way cheaper, we got stuck buying an $80 chain because that was all my local shop had in stock, online could have got it for $40)
Machine Shop 50
Bearings 41
