06 WR250 not getting fuel
Thank you for any help - new here. I am working on an 06 WR250 that sat for 2 years. Gas was bad - drained tank and carb, removed float bowl and jets and cleaned all the gummed up areas. Not getting fuel from the gas line to the carb. It flows out of the gas line from tank, but not getting any in the carb. I don't see any other clogged areas, and needle jet moving up and down with clear jet passages. Thoughts? Thanks again for any info.
