Mobil1 10w-40 on a TE-570?
Hi.
I'm new on the forum, and also to the world of Husqvarna bikes.
I just broke the kick starter axle on my TE-570 the other day, and of course will have to put in new oil when I get the new axle.
Is it ok to use Mobil1 10-40 semi synthetic oil in this motor?
Thanks
Steinar
Mobil1 is great stuff, and I ran it for years in all my Huskys.
The only problem is Mobil adds an additive that will make your clutch plates wear out a lot faster than they should.
Apparently the stuff is great for contact loads like gear to gear or bearing to bearing, but bad for friction loads like clutches.
There are a lot of good 4-stroke motorcycle specific oils out there... just buy a quality brand and you'll be fine.
