06' 250R Seems to Eat Oil After New Piston
There's about 10hrs on my new piston/valves and my bike is low on oil after every ride. Granted there are times after a wreck that the bike is on its side for awhile and at first i thought i might have been loosing oil through the over flow, but there's days were the oil is low even if the bike hasn't been down. There's not any visable smoke in the exhaust, so i'm assuming there's no blow-by and i haven't noticed a leaks. Everyone have any ideas what the issue might be?
check your gearbox oil level next time you drain it. Fill it with 800ml and measure it again next time it comes out.
If it's building a crankcase seal has gone and your pumping the engine oil into the gearbox
