Difference between these 2 flywheels?
Both flywheels are supposed to be from 2003 CRF450R's, but the second one has another type 'inner metal ring' plus an extra teflon ring.
Can someone tell me from what bike the second flywheel is, and why it's different from the first one?
Thanks! ­čśĆ
  • 2 weeks later...
Sorry for the delayed reply. I really cannot find that stock flywheel at the moment, so I cannot compare their weights.
The first flywheel is a stock Honda flywheel. The second is a six year old Trail Tech flywheel.
Thanks for the info! The second (TrailTech) flywheel weighs 895 gramm. Do you know how much heavier that is than the stocker, and which bikes it will fit? Oh, and is it the lighting or non-lighting version? Thanks again :banana:
Edited by FrankV
... and which bikes it will fit?
I already found out it should fit the 02-08 CRF450R :banana:
edit: I found the stock flywheel. It weighs 625 gramm, so the TrailTech is +270 gramm
Edited by FrankV
├Ś
├Ś
