mix ratios and oils for a 06 yz125?
Okay so heres the deal im geting a 06 yz125 tomorrow, I've owned a bike but never a 2ts. So could you guys help me out? What is the best oil to use when mixing? Also, what is the best mix ratio? I'll mostly be riding around the farm witch consists of open field, trails, jumps, and a little track at my neighbors. I like to ride hard if that matters. Thanks alot guys, please reply soon ­čśĆ
The smaller the displacement the higher the rpm=more oil the better
The harder you twist the throttle=more rpm=more oil the better
Personally on a 125 i wouldn't go and higher than a 32:1 ratio, if you jet for it and your riding style you'll be golden
As far as oils pick your flavor, do a search on premixs you'll stay busy for a while
├Ś
├Ś
