02cr250r
Take off the "RC valve" cover. Turn the pulley fully counterclockwise. Adjust the right cable so there's 12mm from the top of the pulley to the bottom of the threaded adjuster ( I use a 12mm open end wrench to measure the gap). Then rotate the pulley fully clockwise and adjust the left cable until the cable is pretty tight (wont touch the side of the cylinder) but not crazy tight. Thats it. All adjustments are done by backing off the 10mm locknut and turning the adjusters in/out. Hope this helps
