08 CRF450X Wheels onto 99 CR250R
Hi,
Can anyone confirm whether a set of standard wheels (front and rear) from an 08 crf450x will fit straight onto a 99 cr250r?
Would any other parts (brakes, axle etc) be required to make them fit?
Thanks.
Without modification, no.
The 99 rear still has the 20mm axle, and the CRF's use a 25mm. The disc has a different bolt pattern, but should have the same diameter.
The front would fit width wise using the 99 left spacer, but most likely doesn't have a stop for the odometer drive on the X wheel. You would then need a drive replacement spacer.
