Mikuni TM34 help
The blue circle is the inlet needle and you can bend that tab to have the needle close much sooner (very little bend goes a long way)
The red circles are the arms that the floats hit to actuate the inlet needle. You may have to try a couple of times but bend a little at a time till the fuel stops overflowing.
One other thing to check is make sure you didn't put the floats in upside down.
