Well I finally did it
I got my bike back together. Its a 2007 CRF250X
It now has a JD jet kit in the carb
165 main jet
CC mods to the airbox
Uni airfilter
Removed backfire screen
FMF powercore 4 muffler
stock header
Wiseco 13.5:1 Piston
Kibblewhite Stainless Valves and Springs
Hotcam Stage I Cam
Disconnect Pink Wire
It fired right up on the first pop, which was nice considering it refused to start once the valves went out.
I hope to take it out tomorrow and put around to seat the rings.
The carb has to be some kind of Japanese torture device. It barely fits in there. Hooking up the hot start was a real pain and so were the throttle cables. I had to remove the rear shock. I have also developed a deeper hatred for threaded aluminum
Don't put around on it, ride it like you stole it, hard acceleration and decleration. Warm it up for at least five minutes before you ride it hard. I put the same piston in mine, love it, awesome improvement in power for the extra money.
The first time I re-installed my carb, I just about went insane trying to re-connect the hot start. It's near impossible. Since then, I've just disconnected the hot cable at the handle-bar lever and take off the carb with the cable attached and put it back on with the cable attached. Much, much easier.
