Another drz400sm jetting question
Ok I just want to make sure I have the correct setting. just got the jd kit and k&n from tt, still waiting on the MRD SSW... this is the settings I found searching on this forum:
I'm in tucson..
elevation: ~3500. temperature: +75F
MRD SSW w/ quiet insert, K&N, 3x3
160 main jet
jd blue needle
clip 3
stock 22.5 pilot jet
2.75 turns fuel screw
Is that good? Or should I use a 150 main jet and red needle? JD instructions says that I should use red needle for altitudes higher than 4000, but also for high temperatures so I'm not sure.
thanks
