What size/kind of tubes ???
It depends on what type of tire you're installing ... radial tires should have tubes marked for radial tires. If the tires are bias ply, any tube will work as long as it's the right size.
Most tubes will cover a range of tire sizes, just make sure the size you need (your tire size) is listed in that range when you buy the tubes. :banana:
