03 CR125 oil under engine?
Buy a can of brake cleaner, that and a stiff brush will have it cleaned in no time.
It looks like the exhaust gasket is leaking ........
Its also good to replace the springs.... they wear out.
Whens the last time the muffler was repacked?
# 10 here:
http://www.motosport.com/dirtbike/oem-parts/HONDA/2003/CR125R/?modelyearid=2&typeid=1&groupId=98
And # 4 here:
http://www.motosport.com/dirtbike/oem-parts/HONDA/2003/CR125R/?modelyearid=2&typeid=1&groupId=117
The Honda part numbers are in the links, you can take those numbers to your local dealer and have them order them for you to avoid motosport's shipping costs unless you're making a larger order.
