RPM Gauges
My guess is that pretty well all of these devices use the same guts from the same manufacturer with slightly different shells and controls.
I'm using the standard Tiny-Tach. The setting switch is mushy so it was a bit of a nuisance setting it up. But it works perfectly and no need to use the control ever again.
http://www.tinytach.com/tinytach/gasoline.php
Here's a pic of my installation. I just used some double-sided foam tape to mount it. Simple and solid.
...ken...
Unless I cant read, I cant see where it says it will work on a 1 cylinder :S
And the other gauges they sell most say a minimum of a 3 cylinder...
I think if you want a tacho, you will need to either fit a trailtech vapor dash, or a tinytach or trailtech mini tach as posted....
They have a Q&A.
You are now chatting with 'Ran'
Ran: Hello, how may I help you today?
Gregg: Will Elite 10 Color Tachometer Gauge work on a one cylinder motorcyce engine?
Ran: it has a one cylinder setting on the back of the gauge
Ran: so it should work
Gregg: Thank's
I got one on eBay recently
Oz$51 delivered to Oz/Tassie.
Item was titled "Trail Tech TTO Tach-Hour Meter Computer Digital Gauge"
Hey DonQx , Thanks for the Heads Up ...:banana:
Just purchased this one...only $6 shipping to Australia...Just a tad better than $101....:eek:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=220647087562#ht_500wt_749
├Ś
├Ś
