quick dumb question
Isn't the SX a 4 speed for closed course SX & MX, where the XC is a 5 or 6 speed and the XC-W is a 5 or 6 speed wide ratio, both meant for off-road, but with no light? I don't know KTM's, but I thought that's what I read at some point.
OK, found this.............
ENGINE >> 2009 KTM 450 SXF
Engine type Single cylinder, 4-stroke
Displacement 449.3 cc
Bore x stroke 97 x 60,8 mm (3.82 x 2.39")
Compression ratio 12.5:1
Starter E-Starter/12 V 4 Ah
Transmission 4 gears
Carburetor Keihin FCR-MX 41
Control 4 V / DOHC with finger followers
Lubrication Pressure lubrication
Engine lubrication Motorex, SAE 10W50
Primary drive 29:74
Final drive 14:52
Cooling Liquid cooled
Clutch Wet multi-disc clutch, operated hydraulically
Ignition Kokusan
CHASSIS >> 2009 KTM 450 SXF
Frame Central double-cradle-type 25CrMo4
Subframe Aluminium
Handlebar Renthal, Aluminium Ø 28/22 mm
Front suspension WP-USD Ø 48 mm (1.89")
Rear suspension WP PDS shock absorber
Suspension travel front/rear 300 / 335 mm (11.81 / 13.19")
Brakes, front/rear Disc brakes 260 / 220 mm (10.24 / 8.66")
Rims, front/rear 1.6 x 21"; 2.15 x 19" Excel
Tires, front/rear 80/100-21"; 110/90-19"
Chain 5/8 x 1/4"
Main silencer Aluminium
Steering head angle 63,5°
Wheel base 1475 ± 10 mm (58.07 ± 0.38")
Ground clearance (unloaded) 380 mm (14.96")
Seat height 985 mm (38.78")
Tank capacity approx. 8 liters (2.11 gal)
Weight (no fuel) approx. 104.6 kg (230.6 lbs)
ENGINE >> 2009 KTM 450 XC-F
Displacement 449.30 cc
Bore x stroke 97/60.8 mm (3.82/2.39")
Starter/Battery E-Starter / 4 Ah
Transmission 5 gears XC semi-close-ratio
Carburetor Keihin MX FCR 39
Control 4 V / OHC with cam levers
Lubrication Pressure lubrication with 2 Eaton pumps
Engine lubrication 10W50
Primary drive 29:74
Final drive 14:52
Ignition Kokusan digital SX
CHASSIS >> 2009 KTM 450 XC-F
Subframe Aluminium 7020, removable
Handlebar Neken Aluminium Ø 28/22 mm (1.10/0.87")
Front suspension WP USD Ø 48 mm (1.89")
Rear suspension WP monoshock PDS
Suspension travel front/rear 300/335 mm (11.81/13.19")
Front brake 260mm (10.24") disc, Brembo double piston
Rear brake 220mm (8.6") disc, Brembo single piston
Rims, front/rear 1.60 x 21"; 2.15 x 18"
Tires, front/rear 80/100-21"; 110/100-18"
Chain X-ring chain 5/8 x 1/4"
Steering head angle 63.5°
Trail Adjustable
Wheel base 1475±10 mm (58.07±0.39")
Ground clearance (unloaded) 380 mm (15")
Seat height 985mm (38.78")
Tank capacity approx. 9 liters (2.38 gal)
Weight (no fuel) approx. 108.3 kg (238.76 lbs)
