New Cam help
Your best bet is to buy a manual. It will have all the info you need to do the job if you are mechanically inclined.
You will have to remove the cam chain tensioner, decompression mechanism, cam gear, and the cam holder to change the cam. You may also have to reshim the valves once the new cam is installed to get the valve clearances back to spec.
